Is there a way to toggle off all layers from the search widget
2333
07-03-2023 12:40 PM
AyeletGreenberg
I’m desperately looking for a way to toggle off all layers from the search widget in ArcGIS Experience Builder.
Currently, you can toggle all the layers On from the search widget, but you have to manually deselect each layer. It would be more useful if there was a way to uncheck the ‘All’ option, to deselect all layers.
I have a map with over 30 layers. In Web AppBuilder there is an option to search all layers or only one layer by selecting it from the layer’s list. In Experience Builder, if you want to search only one layer, you need to deselect every other layer individually. Doing this with so many layers is not practical.
I contacted Esri about it a year ago, and they added it to their enhancements list, but it is ‘under consideration’ with low priority, which means that it will probably never going to happen.
Web AppBuilder will retire in a year, and I need a solution.
Without this option I can’t transfer the app from Web AppBuilder to Experience Builder.
Am I the only one who encountered this issue?
Any suggestions? Solutions?
Thanks
AyeletGreenberg
As promised by esri, yesterday’s release fixed this problem - users can now use the All checkbox to turn every source on or off.
https://doc.arcgis.com/en/experience-builder/latest/get-started/whats-new.htm
AyeletGreenberg
MichaelRuffino1
What a disappointing solution!
