Is there a Summary (Group By) option available in the Table Widget in Experience Builder?
2271
01-07-2025 02:07 PM
hnam
Hello,
I wanted to ask if the Table Widget in ArcGIS Experience Builder has a built-in summary (Group By) feature. In the ArcGIS Dashboard app, when adding a table, there is a "Grouped Values" table type option available, which automatically generates summary values (please refer to the attached screenshot).
However, I am unable to find a similar option in the Experience Builder Table Widget, which has made it quite challenging to display summarized data effectively.
I came across another post suggesting creating a summary table in Dashboard and embedding it into Experience Builder as a workaround. However, I’m unsure if this is the most effective or recommended solution.
I have also tried a workaround by creating a grid-style table in Experience Builder, using the Grid Layout and linking text elements to a data table. However, this method felt overly complex and difficult to maintain.
Would embedding a Dashboard within Experience Builder be the best solution, or is there a more direct way to achieve summary tables within Experience Builder itself?
Thank you for your help! 😊
GlenShepherd
Hey @hnam
Unfortunately configuring statistical inputs is not available in the table widget yet.
andeb31
Any indicator on when this functionality might be available?
Shen_Zhang
Hi @hnam, have you ever tried the Statistics data action? The summary is not supported in table but you can leverage the statistics action to view some certain indicators.
Shen Zhang
