Is it possible to customize a bar/column chart's tooltip?
1017
09-02-2025 02:41 PM
LauraWaddle_-_FS
@Wei_Ying @Jianxia
Hello ESRI Experience Builder team!
I am using the Developer Edition of Experience Builder (v 1.18) and was wondering if it is possible to customize what appears in the tooltip (when you hover over a bar/column) of a bar/column chart?
For example, I created a chart (screen capture attached) showing the sum of acres burned by property type. Where the tooltip says "Sum of Burn Acreage," I would like for it to simply say "Acres Burned."
Do you know if this is possible?
Thank you so much as always for the help!
Wei_Ying
Hi @LauraWaddle_-_FS Thanks for your feedback! So far it is not supported unfortunately. We will request an enhancement to the chart component team. Thank you!
Wei_Ying
LauraWaddle_-_FS
Thank you so much for following up! Really appreciate it!
AAlvarez
Is there any update to this?
