Integer Field Not Calculating Using Dynamic Content Expression
1109
10-09-2024 11:03 AM
JustinH
Hello -
I recently ran into issues while trying to perform an added sum of multiple field in EB. I sort of solved some of the issue from This Post  but I noticed that the calculation was rather not working because of one particular field. This field is an integer and calculates perfectly fine in Dashboards. However the field fails in EB....
Hoping someone can help!
 In experience Builder:
Calculation only shows the title of the expression when printed.
However in Dashboards:
The calculation on the same field seems to work perfectly fine.
NicoleJohnson
MVP
I looked at the post you linked, and I see that changing the data from selected to default is mentioned, and you say that you made sure it was set to the default for each field. Honestly, I think something is still pointed to the selected features, and that's why you're only seeing the expression name. I would try re-doing the expression entirely, especially since it's not complicated.
JustinH
Thanks for your reply. For some reason, somehow, some way, or another, the expression started working. I ended up just leaving the field in the expressions (set to default) and the next day I came back and it was calculating correctly. Definitely frustrating but it now works!
