How to show/hide the Edit widget when the user is an editor or a viewer
194
07-08-2026 08:18 AM
JoseSanchez
Good morning,
I am looking for a way to hide the Edit widget in a EB application when the user is a viewer not an editor.
Thanks
JonM32
@JoseSanchez I don't believe you can do this easily.
However, if they are viewers then the edit widget would be disabled and won't let them make edits.
Cheers,
Jon
If this response helps or is the solution to your post, please consider marking it as a solution
JeffreyThompson2
MVP Frequent Contributor
There is not a mechanism for restricting access at the Widget level, but you can restrict a Page by going to General Settings > Privacy and Security > Page Visibility Restriction.
GIS Developer
City of Arlington, Texas
