How to rename columns in Experience Builder Table widget?
1578
12-04-2024 07:28 AM
DiegoMeira
I have configured the fields in the Map Viewer, however the table widget in the Experience builder doesn't honor my configuration.
Map Viewer configuration
 Experience Builder table
Is there anyway to make the table follow my Map Viewer configuration, or to configure the column names within the Experience Builder?
I'm running ArcGIS Enterprise 10.9.1.
abureaux
MVP Frequent Contributor
No current option for that. But sounds like a good Idea.
ShaneONeill_144
It would be great if you raise an Idea for this and contact your local Esri distributor so that an enhancement request can be submitted - its always helpful to provide the link to your idea if you do raise a support case
DiegoMeira
I checked ArcGIS Online and there it seems to be working as it should.
Map Viewer:
Experience Builder:
Would it be safe to assume that the latest versions of ArcGIS Enterprise would have a similar behavior?
