How to remove "Filter types" in Edit Widget
416
10-24-2023 08:40 AM
clopez_CMAPGIS
I was wondering how I could remove the "Filter types" in the Edit Widget. See below:
I'm working off an Experience Builder template.
Damian
I have the same issue. I only have three different classes so I don't need the 'Filter types' box. The box actually makes things confusing for my users. It would be good if Esri would provide an option to hide/remove this box in the Edit widget in Experience Builder.
Regards, Damian
AlixVezina
You'll be able to hide the Settings dropdown and the Filter types search box with the upcoming June update of Experience Builder:
Damian
Excellent!
EricErtl
Hi @AlixVezina.  Not exactly the same question as the OP but is there a way to remove this input within the JS Maps SDK?  I couldn't find anything within the sdk docs and doesn't look to be an option in the visibileElements property.
