How to maximize the popup window in EB
904
05-05-2025 05:39 AM
SanchezNuñez
Good morning,
Is there a way maximize the popup window when a user  clicks of a feature?
We have a popup that has only 6 fields and the suer would like to see the whole list  together.
Thanks
Ke_Xu
by Esri Regular Contributor
Hi @SanchezNuñez,
There isn't a way to manually change the size of the Popup. Since it lives within the View, it's best to not take up too much space. It is a known limitation from JS API.
Please use the Feature Info widget instead.
Ke
Ke_Xu
Hi @SanchezNuñez,
Ke
SanchezNuñez
Good morning @Ke_Xu
I tested adding a feature info widget, with the jewelry template, adding the widget in the slide and it works.
