How to create a hyperlink with a field from a feature layer
1217
05-31-2021 10:35 AM
JohnPaulAlbana
How can I make a field from a feature layer become a clickable hyperlink in a text box? Currently using a data connection with a webmap to display these fields.
See attached file, Thanks
ShengdiZhang
Hi John,
You can select the content and then click the Link button on the text settings to open the set link panel:
In the set link panel, Link to URL and select Attribute:
Hope it helps,
Shengdi
ShengdiZhang
Hi John,
Hope it helps,
Shengdi
