How to configure to create an query widget
1277
03-23-2025 02:31 AM
baohuachu7
My requirement is simple:
    In they widget there is an text or list for input value which worked as condition.  Then a button for execute query and the result to be outputed to an list widget.
For example, there is a pipe layer , to query the features within current map extent and the diammeter which is larger than 0.5m(for user input input).
I researched all the documents not find solution
Laura
by MVP Regular Contributor
I do believe you'll have to set the query field and the greater, less than or equal to. You can set up multiple queries to get all of those options.
Laura
I am a little confused by what you are trying to say. You can use a query widget to make it say Diameter (field) "is greater than" ___. This can also be done using the filter widget.
Within the query widget you can set up a spatial filter to use the current map extent.
baohuachu7
Sorry for my not described clearly.   My question is :
 I expect the  query widget can be configured to this result:user can select  the query type from the list  "is ,is not, is at least ,is less than , is between..."   and then input value to query, and set other options for spatial filter as "current map extent/ all the data source".
Laura
