How to click a record in the Table widget and automatically zoom to that same record in the Map widget.
169
3 weeks ago
SanchezNuñez
Good afternoon,
hbontrager_dgco
Try adding a message action to the table so that when record selection changes it zooms to the record on the map.
hbontrager_dgco
Laura
by MVP Regular Contributor
Ditto @hbontrager_dgco
You can also set up your search bar to search by a field - say I want to see valve 002 if i search 002 it will select and zoom to that on the map!
