How to change view order in the view navigation widget?
1385
07-20-2020 09:12 AM
SébastienMartin
I have a widget section with 4 views. I change the order in the ‘content’ of the widget. When I add the views navigation widget and I select Custom views, the order is not the same. I read in the documentation that the order is setup in the section widget (https://doc.arcgis.com/en/experience-builder/configure-widgets/view-navigation-widget.htm), but it don’t work with a custom view.
(The order in the section widget)
The order is the same in the view navigation when the views is on the “Auto”.
When I want to hide one view, with the custom view, the order is anything.
ShengdiZhang
Hi Sébastien,
Thank you for pointing this out, and I will log this as an issue to see if this can be fixed.
Shengdi
