How to change Tab in Tabs programatically?
1416
08-18-2022 03:50 AM
Robert_van_Gilst
When using the Tabs object, I would like to programatically change the tab that is visible.
I expected that I could update the value-property by setting this.showTab with an id of a Tab to change the tab that is shown. But this is not the case.
  <Tabs
    defaultValue="tab-1"
    value={this.showTab}
    type="tabs"
    <Tab
      id="tab-1"
      title="First"
      <Box
        className="p-5"
        width="100%"
        Content 1
      </Box>
    </Tab>
    <Tab
      id="tab-2"
      title="Second"
      <Box
        className="p-5"
        width="100%"
        Content 2
      </Box>
    </Tab>
  </Tabs>
</div>
RobertScheitlin__GISP
The way I manage it is use a state.  so Tabs value property is set to a widget state called selTab and programmatically I set the widgets state for selTab and it works fine.
Robert_van_Gilst
Thanks @RobertScheitlin__GISP this was exactly what I needed
// Robert
