how does one change the owner of an Experience?
1151
07-02-2024 06:23 PM
john_cartwright_noaa
How does one change the "owner" of an Experience? I've imported an Experience (i.e. application) into a new version of the Experience Builder framework. The experience is not visible when "owned by me" is selected, only with "All". Changing the "username"property in info.json did not address the problem.
Thanks!
--john
Mackenzie_OBrien
Hi John,
Changing ownership of an item must be done in ArcGIS Online- this blog post goes through the steps of transferring ownership of items. Please note that the users must have the reassign ownership privilege to transfer ownership of items.
Thanks for your suggestion but this is a Developer Edition experience running locally. Other than the OAuth credentials (which are already under the new user), I don't think there is a tie to the AGOL.
TianWen
Thank you for your post. Are there any error messages when importing the app? Are there any specific steps leading to the issue?
