How do we switch web maps (> 2) to the same map widget dynamically with Data Actions enabled to layers from active webmap
4041
10
01-25-2025 02:45 AM
Vara_PrasadM_S
Hi Team,
We have a requirement to switch web maps of a single Map Widget dynamically. We have this option in Experience Builder dev edition, but that is limited to 2 web maps. We have a list of webmaps shown in a custom widget, upon selection/click, the web map of the map widget should be changed to selected one. At the same time, the layers from the active/selected web map should have the complete data actions (eg., Add To Table) in Map Layers widget.
We are using Exp Builder Dev edition 1.16
Any help would be highly appreciated
With Regards,
Vara Prasad
RoseZhou2
Thanks a lot! That explains very well!
Rose
