How do I get the layer ID of a layer on a map widget
1735
07-16-2024 12:54 PM
ShahranNewaz
Hi, so I'm working on creating a custom widget that will export the data of a layer into a CSV file. But I'm stuck on the part where I have to retrieve the layer ID of the layer I want to export. This is how I'm trying to do it.
const featureLayer = jimuMapView.view.map.findLayerById('layerid') as esri.FeatureLayer;
 layerid is where the retrieved ID would go. Thx in advance.
QunSun
by Esri Contributor
Hi ShahranNewaz,
Is your problem that you don't know the id of the layer to be exported? If you don’t know the layer id, how do you know which layer to export?
JeffreyThompson2
MVP Frequent Contributor
https://developers.arcgis.com/javascript/latest/api-reference/esri-Map.html#allLayers
The simplest way to find the id of a layer if you don't know it is to console log all layers and look through the results with your browser tools.
console.log(jimuMapView.view.map.allLayers)
GIS Developer
City of Arlington, Texas
