How can I get all the text to display in a widget controller vs ...
900
10-28-2025 08:43 AM
DougBrowning
MVP Esteemed Contributor
No matter what I try here I get text with a ...   How can I get it to show all the text and not cut it off?  Making the container wider does not work.  I see size for icons and button but not text.
thanks
NicoleJohnson
MVP
Depending on how long the titles are, you may be able to get away with adjusting the spacing:
Doing this, I'm able to fit at least as much text as on the left here:
NicoleJohnson
MVP
DougBrowning
I know I tried that but messed something up.  thanks.
Works now
In some ways it does not matter as much since we cannot get selections to be honored when picking a layer from the tool.  We always must use Set as Analysis input.
The only reason we are putting the tools there now is so that when a user does Set as Input then the window will pop open for them.  But if they use select on the map or a widget or a table we do not see it take.  We may even just hide them at this point since a user cannot start with the tool.  They must start with the feature always.  I posted on this a few months ago but no response yet.
https://community.esri.com/t5/arcgis-experience-builder-questions/select-widget-cannot-connect-to-an...
Also it blocks non public layers even for my internal tools.  https://community.esri.com/t5/arcgis-experience-builder-questions/one-or-more-layers-not-publicly-ac...
thanks a lot
JeffreyThompson2
MVP Frequent Contributor
If your on Online, the latest update gives you some options. Selecting Custom for the Size unlocks the Spacing property.
And now you can make the Buttons farther apart.
You can also build your own Widget Controller. https://community.esri.com/t5/experience-builder-tips-and-tricks/the-diy-widget-controller-part-ii-t...
Edit: Not sure why I thought Spacing was unlocked by the new Custom Size option. It's been there for a while and it's there on the other sizes, too.
GIS Developer
City of Arlington, Texas
