HELP! Error Message "Cannot read properties of undefined (reading 'type')"
15900
13
10-18-2022 10:16 PM
OLIVIALUNSFORD
Help! I have been working on this for the last week and I went to complete my home page for the experience today and this happened. I now can't see my pages in the Contents pane, and I can't edit this one with the Contents Pane editor options. I'm freaking out... what do I do? I have a presentation next Wednesday and was hoping to showcase this.
TonghuiMing
Hello @OLIVIALUNSFORD -
After checking, the widget causing the problem has been identified, but we are not sure what configurations had been done prior to this - it is quite weird and probably needs certain specific pre-steps.
The good news is - there is a way for you to resolve this issue on your end.
1. In the builder canvas, select 'Card 2', and then delete it:
2. Save the app and then refresh the browser. It should look fine now.
All you have to do now is to add another Card widget as a replacement and continue building the app.
Thank you,
Tonghui
TonghuiMing
Is it possible to share your app in some way for us to take a look?
OLIVIALUNSFORD
Here is the experience. I was working on the "Need To Know" Page when this happened. I was going to implement hover cards with descriptions for project phases that the user will see on the second page.
But I literally can't even access the Pages section of ExB to delete or add Pages anymore. I was going to delete this one and just start over because of the error, but there's no way to back track.
https://experience.arcgis.com/experience/c0c1005cec73457196d5c2b665d134f6/page/Need-to-Know/?draft=t...
TonghuiMing
I cannot access it unfortunately
OLIVIALUNSFORD
Sorry - give it a try now.
TonghuiMing
I can see it now and we will take a look at it. In the meantime, it would be helpful if no further savings are done. Thanks for bringing it up.
TonghuiMing
Thank you,
Tonghui
OLIVIALUNSFORD
That worked! THANK YOU!
Laura
by MVP Regular Contributor
I am having this issue with the search widget - after it was previously working. When I try to add an action is pops  up with that error.
TonghuiMing
@Laura Which environment and version are you using? If it's AGOL, can you share the app with us to take a look at? Thanks.
