Have Near Me widget results be different from map pop-ups
1192
08-20-2024 10:38 AM
Marisa_Kordecki
I have an experience builder where I am using the Near Me widget which on selection will trigger the pop-up. I would like to have the results from the near me show only a few fields while the pop up would have significantly more fields and information.
Is that possible?
Ke_Xu
by Esri Regular Contributor
Hi Marisa_Kordecki,
You couldn't configure the popup in Exb, but you could configure it in Map Viewer.
Ke
Marisa_Kordecki
Editing the pop-up isn't the issue. It's that near me information uses the map pop-up and I would like the near me to be different from the map's pop-up.
LikaLoechler24
Did you ever get an answer to this? I have the same question. Thanks 🙂
Marisa_Kordecki
nope ☹️
