Give a unique map title for each map in a 2 map design
1946
03-21-2024 12:06 PM
MPach
I'm trying to figure out if there's a way to a unique map title to each of the 2 maps in my dual map design application. This picture might help to clarify things.
This is one map window that contains 2 maps which are nearly identical except for a few differences that are not noticeable immediately. One can toggle between the 2 maps in the lower left corner of the application by clicking. What I'd like to do is give each of these maps a unique title so it's easy to identify which map is active. In this example one is an Overview map and the other is designed for work at a closer scale. I might want to title one "Overview Scale" and title the other "Regular Scale". I also need to make sure the maps extents/zoom level are linked so when one map is zoomed or panned to a particular area if you click on the other map to use it the same location and scale are visible.
Mark
Laura
by MVP Regular Contributor
You can have the extent match if you have 2 map widgets. In map 1 go to action - extent changes - Map 2 - zoom to and it will follow it.
