Forms in map viewer / edit widget in experience builder. Using multiline but boxes not big enough for the text, too much scrolling required.
1418
11-22-2024 02:59 AM
Labels (2)
KatJackson
Hello... hoping someone can help!
I am using map viewer and I have an editable layer. Within map viewer I am using forms to create an editable form to use in experience builder. For the larger fields (with a lot of text) I am selecting the multiline option.
I am then using experience builder and the edit widget. When I select use web map settings it brings my form in and the fields I have selected to be multiline are indeed multi line. The problem is the boxes for the multiline fields are still only 2 lines high and the user needs to scroll down to read it all. Which is hard for the fields with a lot of text. Is there a way to make these boxes bigger? Or a different tool I can use?
Many thanks 🙂
Allen_Zhang
Hi KatJackson.
Map Viewer and Experience Builder have the same behavior(2 lines), so this is a Map SDK's Editor/FeatureForm issue.
You can enlarge the multiline input by dragging the right-bottom corner both in Map Viewer and Experience Builder.
