Fly Controller
2129
07-03-2021 08:47 PM
RodWoodfordOld
Hi, Is there an issue with the fly controller in the latest version. I cant seem to access the setting control or run the fly through. Any advice would be great.
cheers
Rod
RodWoodfordOld
Cheers that solved the issue. The extra click is a little confusing for end users!
TonghuiMing
Hi @RodWoodfordOld - I am not sure which fly mode you are using, but if it's the drawing, after AGOL June release, we support an intermediate stage which allows users to adjust or edit the drawing, to provide more flexibility. Thus, now it requires an extra click on the map area to finish editing and generate the drawing successfully. See the following video:
(view in My Videos)
Basically, when the map is ready, then drawing tools are active; when the drawing process is completely finished, then the setting or play function will be available.
Let us know if that solves the problem you've encountered.
Best,
Tonghui
RodWoodfordOld
