Flash trigger with two maps
859
12-23-2019 01:58 AM
MatthiasDufour
I created an Experience with the "Map View" model :
https://experience.arcgis.com/stemapp/4c77e16f7e284880b1103455dc5d12ca/
In the Map widget, there are two maps (one in 2D and one in 3D), with the same data.
In my List and Feature Info widgets, I set up a "Flash" trigger for the map.
My problem is that this trigger only works with the 3D map.
How should we configure so that the "Flash" trigger works with both maps?
I have the same problem when I select a feature on the map.
I set up a "Record selection change, diplay feature" trigger to update the Feature Info widget. It only works for the 3D map.
Is it possible to have the same action on both maps?
Thank you
