Using the Experience Builder: I have a variable within a dataset that has 5 different categories, which are represented on a map. I created filters (using a filter-widget) so I can view each of these categories separately on the map. Thus, I set up 5 different filters using a single filter-widget. In other words, the 5 filters I implemented are contained within one filter-widget. Everything works fine: if I deactivate the filter for features classified within category A, all features in category A disappear, and the other categories remain visible on the map. The same happens when I activate/deactivate the filters for categories B, C, D, and E. The problem is, when I deactivate all the filters at the same time, all features reappear instead of remaining hidden. Do you have any suggestions on how I can solve this issue?
