Filter widgets based on spatial select stopped working
1661
6
11-13-2024 10:43 AM
SarahTaigelNRT
As of the update today Exp Builder no longer filtering tables and charts.
I have a map with six polygons and 70 points across those polygons. The points hold WQ monitoring data. I have a series of charts which show the data trends of these variables and they are filtered by the selected polygon.
No changes have happened to the dashboard, the data or the web map. But as of the services coming back online this afternoon when I select the polygon the charts do not filter.
Thoughts?
Stephanie_F
Hi @SarahTaigelNRT I suggest reporting this to Esri Technical Support if possible https://support.esri.com/en-us/contact
SarahTaigelNRT
I've logged it with the UK Esri support - it seems very similar to a bug that occurred after the first release of 2024 so I'm thinking its a patch that has been misplaced
Wei_Ying
@SarahTaigelNRT thanks for your feedback! Unfortunately we cannot reproduce based on your description. As Stephanie suggested, please contact Esri support if possible to give us a reproduce steps or application. Appreciated.
Ke_Xu
by Esri Regular Contributor
Hi @SarahTaigelNRT,
Could you share a sample app for us to troubleshooot?
Ke
SarahTaigelNRT
The data is sensitive so can't share the app in a public space
SarahTaigelNRT
Logged call with ESRI UK and after they could not duplicate the problem I initially thought I'd fixed it by taking the polygon select layer out of the grouped feature class (It was published from ArcPro). However the issue persists even with a simple polygon layer and a point layer. It seems this is a bug but I don't know if it has been registered with ESRI Redlands yet.
