Hi, our experience builder app is having issues populating the options within the filter widget when set up to use "All unique values of this field." The list is blank even though this used to work before. I have tried recreating the filters and that did not make a difference.
@Jianxia We are also experiencing this issue on a number of different experience builder apps. I also tried recreating filters and that did not resolve the issue. Please, fix this 😐
@ChristinaNeal and @LJackson29 , thank you for letting us know. I was not able to reproduce it. Could you share a reproducible app or contact Esri Support?
@Jianxia Per @NeilWebber Ours are also related to published services. We will open a ticket.
Also confirming the same issue, but in my case it seems to be specifically with published web services. Appears to work OK with hosted data sources.
I have lots of ExB apps that use 'all unique values' filters, all of which were working perfectly before Friday's update, but no longer populate with options as per Christina's post.
