Feature Report widget won't allow Mobile Worker to generate report
4209
7
07-31-2024 01:48 PM
jdelprete
I am trying to use the new Feature Report widget, but one of my users is reporting that she gets a message that says, "Generate Reports Failed: you can choose to upload result files to ArcGIS Online but you do not have the privilege of creating a new item."
I have confirmed with my organization's Admin that her role does allow to print feature reports, and she has been able to do so from the Survey123 website.
Something I have noticed is that the widget does not allow for the option to "skip and don't save this report" as the Survey123 website allows. Could this be the issue?
I'm hoping there is a setting that I am missing. This widget is not going to be very useful for me unless user types lower that Creator level can utilize it.
2 Solutions
ZhifangWang
Hi @jdelprete ,
Thank you for the feedback. We confirmed this is a bug in the Feature report widget in Experience Builder and it should work in the same way as the Data page on the Survey123 website. The fix is planned in the next update of ArcGIS Online.
For the option "Skip and don't save this report", just to clarify,
  • It means when the report file name conflicts with an existing item in your account, this option leads to drop the new report file and don't update the existing item in your account.
  • In ArcGIS Online, the result report will always save to user's account as an item (unless the user does not have "create content" privilege) since it costs credits; in ArcGIS Enterprise, the user can choose save the result report file or not in the account.
Is this option the expected behavior in your workflow?
Ruth_JiatengXu
Hi @jdelprete ,
We have implemented this feature in the feature report widget, and you can try it when the ArcGIS Online is updated which is planned for mid November.
Ruth
ZhifangWang
Hi @jdelprete ,
jdelprete
Thank you for the reply.
Also thank you for the explanation of "Skip and don't save this report", that does make sense to me.
When is the next update of ArcGIS Online planned?
Ruth_JiatengXu
Hi @jdelprete ,
Ruth
Ruth_JiatengXu
Hi @jdelprete ,
The 2 issues you reported on the feature report widget has been fixed on the production environment. Please let me know if you have further questions.
Ruth
ZhujingXia
Is there a work around to use this widget for feature layer but not in survey 123?
Ruth_JiatengXu
Hi @ZhujingXia ,
We are working on this feature right now. I encourage you to raise an Enhancement case to Esri Support. Our Support team will assign an official bug number for your records. This number can be used to search for and subscribe to the bug on the Esri Support site. If the issue is reported by other customers it will be attached to the same bug report, which helps us assess the impact of the issue and prioritize it accordingly.
ZhujingXia
Thank you. I will do that.
