Feature info attachment display size
1513
5
05-01-2025 06:22 AM
nf3
I'm making an experience to review records, and I have it set up so that when you click on a record in the table, images attached to the Survey123 record pop up in a Feature Info Box (which is nested in a sidebar). I previously had it so that it displays a single large image with a scroll bar to see the others, but I had a source layer get corrupted and now I can't figure out how I achieved those settings. Now, it displays three small thumbnails in a column. I feel like I've clicked everywhere but can't get the look to match what I had before.
Thanks!
Wei_Ying
In Map view, for the layer's popup setting, you can change to display the attachment as gallery
Wei_Ying
Hi @nf3 thanks for you feedbacks!
You can try to configure the attachment setting in the popup setting in map viewer.
Feature info just honors the popup settings for the layer.
nf3
How specifically do I change the settings? I can't figure it out. I want it to be so the image name isn't shown and the image takes up the majority of the space.
Wei_Ying
nf3
Oh gosh, that fixed it, but it's so confusing. I thought you meant map viewer WITHIN the experience. That language should be made much clearer within the Feature Info Widget page.
Wei_Ying
Sorry for the confusing. We will try to make it more clear. But now you see the Feature Info widget is honoring the popup setting of a layer, usually controlled from the Map View of your organization.
