Extent Filter on layers added to table by user
1163
05-16-2024 11:04 AM
IanStaufferWMU
I just recently started learning Experience Builder to replace our webapps currently running on WebApp Builder.
I figured out how to filter the data table based on map extent to all layers manually added. However, when in Live View, if a user uses the "add to table" button in the layers, this new data tab will not be affected by that same trigger.
Is there any way to include this in the triggers?
Shen_Zhang
There's no way to filter sheets opened from Add to table, as the data being filtered has to be selected as Action data first. You may consider use this workflow:
Extent changes -> Data filtered in other widgets -> View in table
It may not be the ultimate solution but it can somehow allow you to see filtered records in table.
Shen Zhang
Shen_Zhang
@IanStaufferWMU, this issue should have been resolved in ArcGIS Online. Please let me know if you encounter any further issues with this. Thanks!
Shen Zhang
