Experience Builder
410
08-18-2025 03:03 PM
SueBoelk2
Does anyone know one can add transparency to the basemap aerials used in Experience Builder?
We are looking to find out if the transparency is set in webapp builder will transfer to Experience Builder but as WebApp builder is being phased out, that option may not work.
Thanks for your input.
EmilyGeo
Hi @SueBoelk2
You can set transparency on the basemap in Map Viewer and that will carry through to other apps like Experience Builder.
In Map Viewer, drill into the basemap and use the Transparency slider in the Properties pane, then save the map and open in Experience Builder.
SueBoelk2
Thank you EmilyGeo, I appreciate your help.
