Experience builder widgets breaking with data source update
1521
07-19-2023 10:46 AM
Swaka
I have an experience builder app with a webmap containing feature services as the data source. For some reason when I update the webmap and resave it (using ArcPro) my search bar and table widgets all break and I have to relink and reconfigure my data sources. Is this normal behavior or is there something I'm not doing correctly? Thanks!
DanJiang
Hi @Swaka ,
I am afraid it is a known-limit for ExB apps. When resaving webmap in Pro, the underneath data source ID changes thus the link breaks. Can you try updating the web map in Map Viewer instead?
RoshdKhatib
Hi , I am having the same issue , but since it a well known limitation this will make ExB useless in a case where there is a constant data and maps updates ?
