Experience Builder Widget Controller Open widgets on loading setting not working
2161
5
03-03-2025 10:59 AM
Ellie_Linden
I have a Web Experience with a Widget Controller widget containing a Map Layers widget. The Widget Controller settings are configured so that “Open widgets on loading” is set to be the Map Layers widget. This worked correctly until recently, so when the user entered the page the Map Layers widget used to correctly open upon loading. However, this functionality is no longer working correctly, where the Map Layers within the Widget Controller no longer opens automatically when entering the page. Something I noticed is if you navigate to a different page then navigate back to the page containing the Widget Controller, then the Map Layers widget does open automatically as expected. Could this be a bug related to the latest AGOL update?
Allen_Zhang
Hi Ellie, this could be a bug. I’ll do some research on this.
Can you share the app with me, or more details?
Stephanie_F
Hi @Ellie_Linden do you still see this issue if you toggle the "Open widgets on loading" configuration off and back on for your Map widget, then save and publish your Experience? I am not seeing the same behavior in my own application.
If the behavior persists I suggest a tech support case for deeper investigation. https://support.esri.com/en-us/contact
Ellie_Linden
@Stephanie_F I did try and turn that setting off/on in the Widget Controller widget and saved/published a few times but it didn't solve it. I also tried re-adding the re-widgets fresh but the issue persisted. I'm not sure if I'll have time to officially log this right now with some tight deadlines. Is there someone I can share the Web Experience with on AGOL?
Ellie_Linden
This seems to now be resolved!
AmyRoust
Did this bug come back? I'm troubleshooting the same way Ellie did and am not getting a widget to auto-open on load.
