Experience Builder unable to use subfolder path in Ajax requests
739
05-21-2025 07:56 AM
othke
Hello
When using the ArcGIS Experience Builder v1.17 with the --path option as documented in the [installation guide](https://developers.arcgis.com/experience-builder/guide/install-guide/), the client-side code fails to honor the subfolder path in Ajax requests.
Environment
- ArcGIS Experience Builder: v1.17
- Web Browser: Chrome
Steps to Reproduce
1. Start Experience Builder with a custom path: npm start -- --path /exb
2. Access the builder at: https://localhost:3001/exb/
3. User is redirected to: https://localhost:3001/exb/page/set-portalurl
4. The page attempts to fetch data from https://localhost:3001/signininfo (missing the /exb prefix)
5. The request fails with a 404 error
Expected Behavior
The Ajax request should be made to `https://localhost:3001/exb/signininfo`, respecting the subfolder path.
Actual Behavior
The Ajax request is made to https://localhost:3001/signininfo, ignoring the subfolder path.
Root Cause Analysis
In the client code (client\dist\site\widgets\set-portalurl\dist\runtime\widget.js), the fetchSigninInfo method constructs the URL without considering the subfolder path:
fetchSigninInfo() {
  const t = `${window.location.protocol}//${window.location.host}/signininfo`;
  return window
    .fetch(t, { cache: "no-cache" })
    .then((t) => t.json())
    .then(
      (t) => (
        this.setState({ signinInfos: t }),
        this.getDefaultPortalUrl(t).then((t) => {
          this.selectPortalUrl(t);
        t
    .catch((t) => (console.error(t), t));
Other widgets in the codebase appear to use a utility method ${e.urlUtils.getFixedRootPath()} to correctly retrieve the subfolder path prefix. This method should be used in the `set-portalurl` widget as well.
Impact
Users cannot run Experience Builder in a subfolder configuration, limiting deployment flexibility.
Thanks for your help
ShanonLoughton
Bit old but for the archives:
Replacing client code (client\dist\site\widgets\set-portalurl\dist\runtime\widget.js), in the fetchSigninInfo method:
with
const t=`${window.jimuConfig.baseUrl}signininfo`
fixes it I think. Not exhaustively tested. Note that no slash needed before signininfo.
- Shanon Loughton (Esri Australia)
ArcGIS Enterprise on AWS, Azure & Google Cloud Professional
