Experience Builder Timeline widget won't filter Charts
958
11-25-2025 01:41 PM
JennaTiller_1
I'm having trouble getting a Chart widget in one of my Experience Builder applications to interact with my Timeline widget, and I'm looking for some advice!
My ExB app uses a time-enabled feature layer in a web map as the data source for a timeline widget. The timeline filters a web map widget, a list widget, and two text widgets with zero issue.
I added a chart widget to ExB that uses exactly the same data source/data view as the list widget, but the chart won't filter based on the timeline. The values are completely static. The chart is a Bar chart categorized By group using a text field, and the statistics are the sum of a numeric field (FTE Count). The chart values seem to be the sum of the FTE count at the first timestamp in my data table, not a sum of the FTE count at all timestamps.
I had a different chart widget that used to work with the timeline, but that broke at some point in the last few months, and I haven't gotten any charts to work since.
Since the timeline widget works great with everything except the chart, and the chart uses the same data source as other widgets, I'm inclined to believe it's an issue with the chart widget rather than the data or time settings.
Has anyone else run into this issue? I'm out of ideas, so any suggestions are appreciated!
TonghuiMing
Hi @JennaTiller_1
We've come across some similar issues with the Chart not responding to the Timeline earlier, but that was around November 2024 to March 2025 - one was due to the chart refresh mechanism, and the other was configured with message actions scenario. We haven't heard follow-up issues since the fixes.
What is your environment and version, AGO, Enterprise? Also, is there a sample app that you can share with us to reproduce the issue? Thanks for bringing this up.
JennaTiller_1
I'm using ArcGIS Online. I can share a link to the application with you or create a copy, but I'm not sure if that will help... do you need me to create copies of the app and its data to troubleshoot?
