Experience Builder- Table Widget Problem
2383
04-19-2023 12:36 AM
OznurGeze
Hi all,
I have an issue with table widget in Exp.Builder. There are some survey data in my table. It is updating so much so fast, refreshing the page constantly and because of that I cant edit or examine my data from it. Is refresh interval could be changed? I use my map in other pages so I'd like to keep the interval same if the problem causing from the map.
Is there any other solution?
  Thanks in advance,
öznur
Shen_Zhang
Hi @OznurGeze
Data refreshing interval setting can be found in Data:
  • Select your data source, you will see a Layers containing all the layers in this data
  • Select the layer which table is using, click the icon next to Refresh setting, Auto refresh toggle will show up
  • Turn on Auto refresh, you can choose either to honor layer's setting or use a custom valueScreenshot 2023-04-24 at 09.49.32.pngScreenshot 2023-04-24 at 09.49.32.png
If you are using a layer on multiple widgets (like a table and a map you described), make sure that you reference same layer for all the widgets so that refreshing interval applies on all of them.
Shen Zhang
OznurGeze
Thank you, I changed the widget but I'll try with this adjusments too.
