Experience Builder (Service Layer Authentication for public and Organizational group users )
2205
06-14-2021 02:04 AM
Labels (2)
ismd1805
Hello, Currently I am working on Web Experience Builder. I have a question which explains below,
For example, I have twelve map service layers. I wanted to develop an application with ten layers and these layers will available by users without ArcGIS online login. The remaining two layers will be accessible by the login option. I have share ten layers as public and the remaining two share with the organizational group. But when I build an app with these twelve layers and share it, that always require the credential for both public user and organization group users to access the app. But I have wanted to public users can see with out login with ArcGIS credential.
I was wondering in the Experience builder is there any way to prepare one application where ten layers can see without login and the remaining two layers can see with login.
Thanks in Advance
DaveFullerton
You might try asking this in ArcGIS Online Questions:
https://community.esri.com/t5/arcgis-online-questions/bd-p/arcgis-online-questions
WesleyMarcellCFW
I am trying to do the same thing. we have 2 layers that are editable and somewhat sensitive.  These have quite a bit of custom configuration using forms, so they need to be in this map document.
I have tried to make 2 separate maps, one for public and one for private, but it still has you login before you click the button to change to the other page.  The login prompt makes it look like something is broken on the page for public users, and if you don't login, there's no place to click to sign in.  A full refresh is required.
