Experience Builder Search Icon
645
10-02-2025 08:36 AM
DugganTabitha
We have staff using a community development map and we were alerted that the search bar doesn't function like it previously did. Before they could search an address and it would automatically zoom to the property. They would then pan around the map and look at other locations. To get the map back to the original search result, they would click the magnifying glass again and it would zoom to the property. Now, the magnifying glass no longer does that and clicking on the search result just turns the pop-up on/off.
I don't know if this was always a limitation or if this is something new. Is there something I'm missing? We have the actions on the search bar already set to zoom to for when a record is created, record selection changes, and data filtering changes.
DugganTabitha
As an update - if you add the "pan to" action in your records created/record selection changes then if you double click the search result it will bring you back to your result. Still no luck with the actual magnifying glass icon.
TimWestern
MVP Regular Contributor
Can you post a screen shot of the action steps you setup for the search?
(I'm presuming that you have the search part setup correctly)
