Experience Builder Query widget pop-up displays date/time in Epoch timestamp
914
09-26-2024 01:30 AM
Arvydas
Hello, I use 'Customize' setting under 'Configure each record' in Query Widget setup so I would have a pop-up in a query results when I press on a feature on the map. But on that pop-up the date/time attribute is displayed in Epoch timestamp. This issue appears after we upgraded our Enterprise to version 11.3.0 (build 51575). Any ideas how to fix this? Thanks.
TonghuiMing
Hi @Arvydas, can you share more info on how this is configured in the Map Viewer? And does that look good in MV?
I suspect it has to do with resolving the custom arcade from the API side, but I cannot say for sure until I see more details. Thanks.
