Experience Builder Query Widget Message or Data Actions
3858
8
10-07-2021 12:55 PM
DavidColey
MVP Frequent Contributor
Hello - For the Online ExB Query Widget  -
if we are going to be able to employ a Message Action for:
Records created>Add action>Show on map, there should be a way to remove the graphic from the map when the record is cleared. 'Remove from Map' the created graphic.
As it stands now, the only way to clear the graphic is to refresh the browser, or not use the 'Show on map' message action and only employ the 'Show on map' as a Data Action.  Then we can at least remove the graphic from the map . . . But that sure takes a lot of clicks and is hard for the end user.
I am glad to see clearing the Search clears its graphic.
TianWen
Thanks for the feedback! We'll consider it and make an enhancement.
DavidColey
Thank you @TianWen It would also be very helpful if we could get at or modify the color setting for the return graphic.  As it is, the pale yellow can be difficult to see against light baasemaps. If anything, most users are used to seeing a cyan, much like a selection.
TonghuiMing
The function has been provided in the latest AGOL 10.2 release - now you can customize symbols for the Show on map message or data actions for available widgets.
AmyHut
Could you direct me toward where I can access this setting? I'm trying to mimic in experience builder the appearance of a widget used in web app builder, and the yellow default will throw off users. Thanks in advance!
TonghuiMing
Show on map message action
Data action
ScottByers
What about remove from map?  Did you release an option to clear the layers?
RossFindlayCOC
Also looking for this as an option. Clunky to have to reload browser.
TonghuiMing
For results added from message actions, removing the trigger (such as clearing the query result) would remove them from the map;
For results added from data actions, you can remove them directly from the map
