Experience Builder Print Widget not showing new NearMap 2025 Aerial
1305
05-15-2025 06:58 AM
Labels (2)
TownOfGlastonbury
I’m using ESRI Experience Builder for Portal and Online with NearMap WMS Imagery in the Basemap Widget. I’ve had no issues with previous NearMap Aerial. Currently the new 2025 Leaf Off aerial is not printing in the print widget. I attached examples of the new 2025 and the 2024 leaf on that is working. The current 2025 is using the same NearMap Public URL API as all the other aerials and I also set up the 2025 aerial the same in Portal and Online as the other NearMap aerials in the app.
Thoughts?
LachlanWainwright
Hi @TownOfGlastonbury
Did you get this resolved?
We are experiencing a similar issue with our environment.
Our on-prem enterprise 1091 won't print the wms while the same setup on azure servers does.  We thought it was firewalls etc but alas it's not everything is open ☹️
Thanks
Lachlan
TownOfGlastonbury
Hi Lachlan,
Sorry to hear you’re having the same issue. After contacting ESRI Support they determined it was a bug.  For us it just started working one day.
Here's the BUG that ESRI created.
https://support.esri.com/en-us/bug/the-print-function-in-arcgis-online-does-not-work-with-bug-000177...
