Experience Builder Pie Chart with 'Where' Statement... Of Sorts.
610
01-12-2026 09:49 AM
FlightDeck
Hey All,
I am setting up 2 pie charts in Experience Builder. The first one contains all of the locations in my data set. that is working as expected. For the second one, I need it to show only a specific subset of that data. Essentially I need a "Where field A = X" variable to limit the data that gets read into the pie chart. Hopefully this is simple, but being fairly new to this, I have not yet found a way to do this while poking around.
Also, Preferably this would be a static pie chart and not dynamic or dependent on a filter from the map data.
tmichael_wpjwa
When configuring the data source for the chart, click the drop-down for the layer and then Create a view:
This will allow you to add a filter to the data, and then use the filtered data as the source for the chart.
tmichael_wpjwa
