Experience Builder Near Me Widget not Refreshing
1356
04-25-2025 04:35 PM
KatieHansen
I have an Experience Builder app that has a map as the main focus, an edit widget and a Near Me widget (which is used as the Info Summary widget was in Web App Builder). I would like for the Near Me widget to refresh when edits are made to the polygon features that are within the map using the edit widget. Unfortunately, it seems that the user has to refresh the Near Me widget using the Update Results button in order to see any changes to the feature in this widget. Is there a work around for this that I am missing? Thank you for any insight.
@AzizaParveen1
AzizaParveen1
Hi @KatieHansen
This is by design. If you want to automatically update the results as feature changes (added or removed) please follow the "Set up automatic results update based on map area extent" section of this blog https://www.esri.com/arcgis-blog/products/experience-builder/local-government/recreating-web-appbuil....
You need to set up a extent change message action.
Aziza
BeckyC-O
Hello Aziza,
Does this behavior exist in Enterprise 11.3 Experience Builder applications? I'm unable to get it to work there using the instruction reference page you posted.
Becky
AzizaParveen1
Hi @BeckyC-O , unfortunately no,  it was introduced in 11.5 Enterprise version.
BeckyC-O
Thank you for the info! We will be upgrading to 12.1 in the near future, so it won't be a problem for long.
