Experience Builder Line Chart by Date doesn't start at beginning of the month
3869
9
05-24-2024 04:26 AM
cat206
Hi, I'm not sure if i'm missing something here but i can't seem to figure out a way to have my line chart display in month intervals. The first point in my data is 18th Janauary and the rest seem to follow this:
If i try to use a bar chart, the data just does not display:
Does anyone have any ideas please?
RPGIS
by MVP Regular Contributor
It is displaying in month intervals. It looks like it isn't displaying just the months simply because it is showing January of each year.
If you only want just the months, then either you will have to add a field to indicate which month it was collected/edited or filter the data by a specified year.
cat206
Thanks for coming back to me. Sorry If i haven't explained myself properly but I don't just want the months, It's displaying how i would like to see it so it span from January 2022 to todays date, but when you have a look at the lines it's counting from 18th of each month until the 17th of the next month when really I want to see 1st to Month end (28th/30th/31st):
hopefully that makes sense, so starting 1/1/2022 - 31/1/2022, then 1/2/2022 - 28/2/2022 and so on
RPGIS
I know you can format the dates in Dashboards, but it seems that Experience Builder is still limited in that regards. If you can't find a solution, then you can definitely pitch the idea to Esri to include formatting dates as an idea.
cat206
Wei_Ying
Thanks for your feedback!
We will work on to support date field in bar/column chart.
cat206
Thank you!
cat206
Any idea on a timeframe for this please Wei?
Wei_Ying
Sorry that we cannot guarantee the schedule. But we will try our best.
ClintonBradley
+1 for this. I've got some charts in which I want to display data by calendar year but the only options are to snap to the first or last data point which bins data relevant to the actual min/max dates in the data. This won't make a lot of sense to the user.
