Experience Builder Labels (Rounding to 4 decimal places)
2696
05-21-2024 03:13 AM
StephenDuncan
Morning,
I am fairly new to Experience Builder and writing label expressions in Experience builder which I believe uses JavaScript/Arcade?
I have a field called "WAYMARK_VALUE" which has been rounded to 4 decimal places in the 'Fields' list and it also shows correctly in the pop up box shown below. When applying the labels it seem to have a mixture of decimal places, from zero places and to the correct 4 places, so i am a bit puzzled why this is not working?
I have copied a piece of script I found online which i thought would work, but unfortunately it doesn't seem to consistently work, so any help would be much appreciated.
Once i have the rounding issue sorted, i would then like to add multiple attributes to my label expression, ideally the "ELR" attribute and the "WAYMARK_VALUE" rounded to 4 decimal places. (ie;  BLT1 - 47.0880
Many thanks,
Steve
IssyAmis
Hi @StephenDuncan
Thanks for your question.
Looking into the documentation for the "Round" function, it seems to be expected that any trailing zeros will be truncated - which I assume is the behaviour you are experiencing, rather than the rounding not working at all? https://developers.arcgis.com/arcade/function-reference/math_functions/#round
From what I can tell, there does not seem to be a way at the moment to stop this behaviour. If you take a look through this documentation: How To: Retain Trailing Zeros after the Decimal Point in a Label Using Arcade in ArcGIS Pr (esri.com... we do have a workflow in Arcade to resolve this in ArcGIS Pro that is worth trying for your labels - although I have not yet been able to get this to work in ArcGIS Online.
Let me know if you have any questions about any of the above!
Issy
IssyAmis
Hi @StephenDuncan
Issy
StephenDuncan
Afternoon Issy,
Thank you for getting back to me on this and supplying the links to the information. I have played around with the Text function and it seems to have worked in ArcGIS Online Experience builder on the labels 🙂
This was the script that seems to work for me:
Text($feature.WAYMARK_VALUE,'###.0000')
Hopefully you are also able to get it to work for you!
Appreciate your help,
Many thanks,
Steve
IssyAmis
Hi @StephenDuncan
That's great, I'm glad that's worked for you!
Issy
MatthewStull1
This fix worked for me but there should be a much easier and more intuitive way to do this instead of having to go into the code.
