Experience Builder - Issues with Slides and Symbology
396
9
07-07-2026 05:13 AM
PavelBelsky
A big issue with the June update:
In Experience Builder, if I'm using 3D scene's slides (bookmarks) instead of Experience Builder's native ones - and my scene has vector data layers that have symbology (color/transparancy) - it's broken now.
It messes with the colors/transparancy completely.
What I have noticed is that that happens only if the first slide that has the layer with the symbology - turned off. What happens is that when clicking the slide, the layer appears completely transparent (instead of showing the correct color/transparancy).
StephanieW
Hi @PavelBelsky I tested with my own scene and Experience Builder app but was not able to reproduce the behavior described. A Support case would be ideal for this so we can take a closer look at the items involved and their configurations.
PavelBelsky
thanks for replying @StephanieW . here is a step by step reproduction I just made:
image 1: gispro - polygon layer colored by "type" field.
image 2: agol scene - layer brought in
image 3: agol scene: layer stylized by "type" field and shown in style 3d
slides:
'initial slide': layer is turned off
'slide 1' layer is turned on
image 4: agol experience builder:
initial view slide: ok
image 5: agol experience builder:
'slide 1': no symbology, only edges, doesn't work!
image 6: agol scene:
slides:
'initial slide': layer is turned on
image 7: agol experience builder:
'slide 1': works fine!
I hope that helps!
Ke_Xu
by Esri Regular Contributor
Hi @PavelBelsky,
I couldn't reproduce this issue with my own data. Could you share a public map for us to troubleshoot?
Ke_Xu_0-1783496045967.pngKe_Xu_0-1783496045967.pngKe_Xu_1-1783496068275.pngKe_Xu_1-1783496068275.png
Ke
PavelBelsky
absolutely @Ke_Xu , here you go:
https://experience.arcgis.com/experience/8f3e3ca3dde14358aa5b302f3f3bcf5f
Thanks for looking into it, I really appreciate it!
Ke_Xu
Thanks, @PavelBelsky, we are investing in it. I will keep you updated.
PavelBelsky
Hi there @Ke_Xu . Would you have any updates on the matter?
Thanks!
Ke_Xu
We will have a patch after the User Conference(next week).
Ke_Xu
Hi @PavelBelsky,
This issue has been fixed.
Ke
PavelBelsky
Wow @Ke_Xu Thank you so much for the update!!
