Experience builder - Gauge chart
8506
17
11-17-2023 03:14 AM
ElieRizk2
we are planning to build a dashboard using the ArcGIS experience builder. but we aren't able to find how to create a gauge.
kindly anyone has information on how can reach our target?
michelle-maps
Was this ever fixed? Is there still no way to label a gauge chart?
vinayvamshikrishna
Hi can you share this guage logic code or any wr fo8nd pls give as soon as possbile its urgent requiement
Wei_Ying
@vinayvamshikrishna what do you mean logic code? If you download developer edition, you should be able to see the Chart widget code.
GhaidaAlswayed
can you tell me where can i find it exactly? because I'm trying to modify via coding it or create new custom widgets
Thank you
Wei_Ying
You can find the code at directory:  ./client/dist/widgets.
Chart widget is in "Common" - "Chart" folder
GhaidaAlswayed
I'm trying to add "GW" notation. there's any documentation explain how to modify the gauge?
Wei_Ying
@GhaidaAlswayed Where do you want to add the notation? Do you mean change the notation of the displayed value? You can change the notation at value format
For other note, so far Gauge does not support adding title or description. But you can use Text widget on top of the chart to add any note.
City_of_Edgewater__Fl_GIS_Div_
An odd thing, if you add another gauge widget on top of a guage widget it displays the Title
