Experience Builder export to CSV is not working and is not downloadable to file.
992
10-23-2025 08:14 PM
JT101
Hello,
Export to JSON, GeoJSON, Item, Shape, etc is all downloadable. Exporting a table to CSV does not download the .csv excel file.  Instead it opens it up in Chrome.  I'm not sure if this is a new "Feature", can we have it restore back to the way it was?  Thank you.
VenkataKondepati
Honored Contributor
Not an ArcGIS change—this is Chrome handling CSV inline.
Quick fixes (pick one):
Right-click → Save link as… on the CSV export.
In Chrome: Settings → Downloads → Clear auto-open settings, and (optionally) disable Google Docs Offline so CSVs don’t open in-tab.
Use Edge/Firefox (they typically download CSVs).
If you control the server (not AGOL), set header Content-Disposition: attachment; filename=export.csv so browsers force download.
As a workaround in AGOL, Export → creates an item → Download, then right-click save if needed. You can also zip the CSV to force download.
Bottom line: it’s browser MIME behavior; adjust Chrome or use Save-as to get the file.
Regards,
Venkat
Regards,
Venkat
Follow me on: LinkedIn
If this response helps or is the solution to your post, please consider marking it as a solution
VenkataKondepati
Honored Contributor
Regards,
Venkat
Regards,
Venkat
