Experience Builder (Enterprise 10.9.1) Chart using Date field as Category
2059
12-29-2021 11:22 AM
AllenScully2
I'm looking to build a dashboard type of application in Experience Builder (Enterprise 10.9.1) but am stuck on something in the Chart widget.
In the 'old' Dashboard, you can select 'Features' as an option for your categories.  In the Chart widget in ExB, you can only select 'Grouped' or 'Fields' - this appears to only allow for numeric fields to be selected as a category.
I really need to have the categories along the bottom be dates - it's in the data, all set up, but I cannot get that option in ExB, only the numeric columns.
Is this just not available?
KevinMayall
I have the same issue.  I wanted to try recreating some of my dashboard charts in Experience Builder (Online), but they are time series charts using 'Features' (rows in a hosted table) and it seems the date field is not allowed.
Kevin
Ashok
I am also facing similar issue. I am also looking for the functionality where I wanted to display my data based on Date field (It is a time  series data).
Ashok
