Experience Builder Embed Widget
5953
7
12-17-2021 12:06 PM
ZachBodenner
MVP Regular Contributor
Hello,
I have an embed widget that I have set up to link to a .wav audio file. What I can't seem to figure out is that it seems to automatically play whenever the ExB page is opened, and I can't change this property. Has anyone else experienced this? Also, when I pin the Embed widget, it is visible in builder mode, but completely disappears when in live mode (yet still plays the audio file, just taunting me).
Happy mapping,
- Zach
jcarlson
The embed widget is basically just a "window" to something else on the internet. Because of that, the way its contents display and behave will be totally dependent upon the browser and the URL being embedded. You can embed, say, a PDF, but whether or not a "print" button appears in the PDF viewer that shows up will depend on what browser you're using.
I've got an Experience that I've embedded some audio into. Here is the preview in Edge:
And in Firefox:
Can you try using an <audio> element to see if that works any better? Switch your embed to "code" and type this:
<audio controls>
    <source src="your-audio-url">
</audio>
- Josh Carlson
Kendall County GIS
jcarlson
And in Firefox:
<audio controls>
</audio>
- Josh Carlson
Kendall County GIS
ZachBodenner
That actually works great, thanks for the suggestion! Now the issue is that pinning the embed widget to the top always places it underneath the header, rendering it invisible for some dumb reason. But that's another post, perhaps.
Thanks again!
Happy mapping,
- Zach
jcarlson
If it's pinned, just set a Y offset equal to the size of the header.
- Josh Carlson
Kendall County GIS
ZachBodenner
Yeah I did figure that, but then it's below the header on top of a bunch of content.
Happy mapping,
- Zach
jcarlson
Do you want it on the header? You can totally add an embed widget to the header itself.
- Josh Carlson
Kendall County GIS
ZachBodenner
No, that'd be too easy. I'm building an oral history projects with one page for each interviewee. I'm embedding the full interview audio for each, so it can't be in the header because the actual audio clip needs to be different for each page.
Happy mapping,
- Zach
dpas
Did you figure out how to embed dynamic content from a data source into an embed widget? When I put src="{field_name}" the HTML filter deletes the ="{field_name}"
