Experience Builder Editor not honoring settings when accessed as related record
2809
10
07-23-2025 08:55 AM
SFM_TravisBott
Having some more odd behavior with the Experience Builder Editor widget where it's not honoring defined settings when accessing a related record.
I have multiple layers and I want different editing capabilities for each. The app has been published with an attribute-only edit functionality for the Treatments layer.
In the Editor, with nothing selected, the option to add a record to the treatment layer is disabled, as desired....You can see below where it's not an option in the Editor.
However, when I select the parent record, and I navigate down to the related Treatment records (which I would like to be able to do), you can still see '+ Add Feature' is available, and you can still add features, which is what I explicitly disabled. The ability to edit in this fashion is enabled in the Form in the webmap, but there's no option to specify editing type.
Could someone in in the community help out with a workaround, or, better yet, can somebody with Esri patch this up?
SFM_TravisBott
@AlixVezina Thank you for the note. I am aware of that behavior (which, in my humble opinion, absolutely shouldn't exist), as I've been bitten by it before. I have verified the behavior across different accounts, much the same as my users will access it.
